HP DV6-3005TU Error system temperature 90d
lappatelsrt1
Post by lappatelsrt1 »
Dear All
Problem in HP DV6-3005TU Error system temperature 90d
Anyone help..
Rakesh
Re: HP DV6-3005TU Error system temperature 90d
Post by Rakesh »
check fan working or not if working then check data pin volt 3.3 volt present or not if present then check fan volt 5 volt present or not ... also check cooling past ..
Rakesh
Post by Rakesh »
check fan working or not ..
ChetanSethi
Post by ChetanSethi »
check the fan cpu heatsink
Did you reprogram the bios ??????
lappatelsrt1
Dear all
Problem solved after reprogram main bios
javedsam
Post by javedsam »
bios 100%
lappatelsrt1
yes sir job done after reprogram main bios
