Dear All
Problem in HP DV6-3005TU Error system temperature 90d
Anyone help..
Re: HP DV6-3005TU Error system temperature 90d
check fan working or not if working then check data pin volt 3.3 volt present or not if present then check fan volt 5 volt present or not ... also check cooling past ..
check fan working or not ..
check the fan cpu heatsink
Did you reprogram the bios ??????
Dear all
Problem solved after reprogram main bios
yes sir job done after reprogram main bios
Users browsing this forum: No registered users and 14 guests
