ASUS P5KPL-VM CHASIS PROBLEM SLOVED
DHRUVGONAWALA
Post by DHRUVGONAWALA »
1. JUMPER SETTING OR SOLDER POINT
2. NEW BIOS WRITE
3. CHANGE SQ5 2N7002 ,
EC1,
SR121 10M OHM
SR123 10M OHM
4. ICH_INTERUDER# POINT IN ICH R R R (REHEAT, FLUX REFLOW , REABALLING)
5. OTHERWISE ICH CHANGE
ICH POINT.
I ATTACH DOCUMENT FILE IN PROPER IMAGES.
ASUS P5KPL-VM CHASIS PROBLEM SLOVED.zip
(402.24 KiB) Downloaded 394 times
amit sharma
Re: ASUS P5KPL-VM CHASIS PROBLEM SLOVED
Post by amit sharma »
Easy solution is remove 2n7002 and sorce pin to drain to pf installed problem permant solve
