Dell 4010 UM8 gets off immediately problem solved..
Today received dell 4010 with the problem on display Ok and immediately off generally assumed "ME" issue but during the diagnosis found the signal " power_sw" signal was bit low.
started with acav_in found ok. 3vdc high.
but looks a logic of D2 and D3 conducting according to logic, low this signal as Q5 Ntype got ON because of acav_in and D2 anode side ever kept low.
D2 diode must not conduct in this condition found its conducting, removed this diode and power_sw become normal again put good diode there and laptop start functioning pro
egyeprom
Re: Dell 4010 UM8 gets off immediately problem solved..
Post by egyeprom »
good sharing
Users browsing this forum: Bing [Bot]2 and 157 guests
