hp 15 r
hp 15 r
hp 15r la-a994p
laptop working fine with adapter and charge the battery....
but when remove adapter.
laptop going off ...
and not on from battery side and remove and reinstalled the battery laptop power on ..
plz help i h diagram also..
Re: hp 15 r
hp 15r
mother board number, la-a994p
not hold on battery mode,,
i change discharging mosfte but not solve ,,
all charging voltage is ok...sm clk..and sm bus is also ok
plz admin help me
Re: hp 15 r
no bady for help in this site
rajeshkumar45
Re: hp 15 r
Post by rajeshkumar45 »
javed wrote:hp 15r la-a994p
when you remove adapter which voltage drop out
check and write all voltage status
rajeshkumar45
Re: hp 15 r
dear guru if you think every one have time to reply your post on the spot not possible
be patience :)
Re: hp 15 r
ok sir thanks .....
Re: hp 15 r
problem solved change discharging mosfet
ganeshcell
Re: hp 15 r
Post by ganeshcell »
Sir but u told that u changed discharging mosfet than also same problem.was the mosfet short?
Users browsing this forum: No registered users and 77 guests
