Dell Latitude E4310
PCB: NAL60 LA-5691P
Problem reported: No power on with adapter or battery, not charging.
Observation.
19v was okay but there was no 3.3v ALWP AND 5VALWP, So step by step I checked PU2 (N0608098) for input voltage and enable pin, all okay. I checked for short on 3.3VALWP and impedance was 0.026 ohms but 5VALWP was 0.001 ohms, I realized that was a short, so I deleted shortpad PJP6 to see if short was coming from PL5 or from the board itself and I realized there was no short on the board but short was still on PL5, So I decided to remove PC35 and voila short was gone. PC35 was damage so I replaced and solder PJP6 back and board works perfectly.
Job done.
Dell Latitude E4310 no power on
- IMG_2143.JPG (2.01 MiB) Viewed 5258 times
- IMG_2144.JPG (2.38 MiB) Viewed 5258 times
- Untitled.jpg (13.03 KiB) Viewed 5258 times
- Untitled1.jpg (167.93 KiB) Viewed 5258 times
Re: Dell Latitude E4310 no power on
thankssssss
- Timothygow
The Dell Latitude 2120 has an Intel GMA 3150.
The new MBPs have the 3000.
Does anyone know if there is an opportunity for a hackintosh of this netbook?
