Need BIOS for ZAP00 LA-302P
Need BIOS for ZAP00 LA-302P REV:1.0 (A00) DELL ALIENWARE 13
Re: Need BIOS for ZAP00 LA-302P
please mention the board plate number correctly
its
LA-A302p
any way here is the attached file for you
Good luck
its
LA-A302p
Good luck
- Dell Alienware la-a302p.zip
- (4.18 MiB) Downloaded 278 times
thank you
Thanks for the dump. I inserted a clean region replaced the Windows key. everything began to run very quickly. but alienfx doesn't work. On the motherboard there is still flash memory with a smaller volume. maybe you have a dump from it.
I think this is where the address is stored to manage Alienfx
here is a clean region. you just have to drive in your Windows code
- Alienware13 HEX clear region winXXXX.rar
- (3.92 MiB) Downloaded 215 times
thank you for sharing
