DELL E5400 CHARGING ISSUE
amit sharma
Post by amit sharma »
Strange Foult
Adatper Type - 90w
Bettery Status - NoT A Dell Bettery
FIRST Change A NEw Bettery But same Msg Then Check Shorting In Charging Section But Shorting Not Found Then Check PNP Mosfet But Mosfet Ok
Then Reprogram Bios But Problem Not Solved
I Have EDIT New Service Tag Enter In Bios
PROBLEM SOLVED
BETTERY STATUS - NORMAL
Bettery Charging Working Fine
minhaj
Re: DELL E5400 CHARGING ISSUE
Post by minhaj »
great job sir g
raajkumar
Post by raajkumar »
What is the program you use to Edit service tag. Can you explain ?
mdmahbub
Post by mdmahbub »
What is the program you use to Edit service tag. Can you explain ? i hope give me this sir
computechsalem
Post by computechsalem »
Use hexeditor
Users browsing this forum: Bing [Bot]2 and 9 guests
