Acer bios
Acer bios
need Acer R5-471t-7028 . PC4HCJ REV :2.0 BIOS
- computechsalem
Re: Acer bios
Hi thank you for this .
But this bios is not working on this model . I have same model another laptop its working unit, I copied bios from that motherboard that bios also showing same error ( i check through DC power supply .If I Programmed bios from another same model working unit its taking only lower current rate then original bios )
help me to solve this problem
- computechsalem
Re: Acer bios
What is the error and problem clearly briefshijithmlalvp wrote: ↑Thu Jan 04, 2018 8:54 am Hi thank you for this .
Re: Acer bios
Acer R5-431T - R5-471T - P4HCJ BIOS-EC
- Acer R5-431T - R5-471T - P4HCJ BIOS.rar
- (4.23 MiB) Downloaded 226 times
Re: Acer bios
hi
thank you for this
its working with this bios
thank you for this
