Lenovo A14HV0X rev 4.0
suryajaved
Tips N Tricks - 4
Lenovo laptop
Pcb model : A14HV0X rev 4.0
Problem Reported :- No Power On,
Observation :- Power on process is little bit different to others models, as we have seen most of the laptop motherboard wake on 3v, 5v pwm supply after full fill basic requirements of io controller , but that case is little bit different , one of the comman IO requirement not fulfilled WRST# / LRST1# that is EC reset must be pulled up with 3v alw , was missing,
Solution :-
Start checking power on requirement step by step ,
VIN ,3.3/5V ,PwrBtn voltage ,RTC_VCC, 32.768khz Frequncy
Everything was available but PwrBtn_out not present,
Someone already made an attempt to reprogram bios
So firstly checked with bios but no luck ,
Now Big suspect to any one of io controller requirement is missing,
Then started searching for IO requirements
Found WRST#/ LRST#( EC_Reset) missing
Further tracing for problem found 3.3V on pull up resistor R451 but not on PIN 14 of IO controller
So biggest and only suspect as seen in schematic is C661
Removed and Bingo
The board turned on and
Job done ✅
4 2.JPG (87.48 KiB) Viewed 6007 times
4 1.JPG (65.56 KiB) Viewed 6007 times
Re: Lenovo A14HV0X rev 4.0
GREAT
syednadeemulla
Post by syednadeemulla »
A14HV0X REV.:4.0 bios
syednadeemulla wrote: Thu Feb 01, 2018 7:09 am A14HV0X REV.:4.0 bios
https://www.indiarefix.in/viewtopic.php ... HV0X#p2577
Users browsing this forum: No registered users and 44 guests
