Machine Model: Hp Pavilion 15-ab291sa
Board Id : DAX1BDMB6F0
Processor: Intel Core i5-6200U 2.3Ghz
Ram: 8Gb PC3L 12800s
This computer can't install Operating system, It keeps giving blue screen, with different kind of errors like "PAGE FAULT IN NON PAGED AREA" , "SYSTEM DRIVER IRQL NOT LESS OR EQUAL" KERNEL SECURITY CHECK FAILURE" and so many more errors on each attempt.
I have tried reprogramming the bios, changed the ram sticks, use different hard drives but nothing works.
I need help
Hp pavilion 15-ab291sa can't intall os
- IMG_2129.JPG (1.58 MiB) Viewed 1759 times
- IMG_2127.JPG (1.89 MiB) Viewed 1759 times
Re: Hp pavilion 15-ab291sa can't intall os
brother is a memory error change the ram and then rety install os if u continues face this blue screen problem then flash bios
I have changed the ram several times, I have flashed the bios many more times, changed the 8mb bios chip but still the same way
