Hello,
Samsung RV518 Dim Display Problem Replace LED and Display Cable Also, But problem are same,
Ext Display Working Good
Help...!!!
Samsung RV518 Dim Display Problem Solved
Re: Samsung RV518 Dim Display Problem
please upload screen part no and motherboard part no or pic
Bro
Old screen already working with another laptop
for MB Part No. this is part no...
Model : scala2_R
PCB Code - BA41-01610A
I am upload 2 image plz chk and give any idea
Tnx in anvance
i dont know how to explain in detail
hope you understand
Model : scala2_R
Tnx in anvance
hope you understand
jlcd1 pin no. 4 lcd backlite on supply ?? need their 3v minimum
Yes sir
there are no 3v on pin no 4, even change 7SZ08 -5leg IC, Result are same
im gonna try to put 3v direct, what do u think about....
yes put 3v direct
Yeah Guru,
Job done, a big tnx for you.....
Case Solved... Please Explane Work Done
Hello,
But problem are same, Ext Display Working Good
Laptop Model :Samsung RV518
PCB Model : scala2_R
After suggeation from friends like you, case sloved
Solution :
I put direct 3v JLCD1 Connector on pin no 4
Please see image
Tnx once again for all of people who connected to - indiarefix.com
Solution :
Please see image
