Dear All
Would like to ask i have Dell N5010- MB Model : DG15
Have problem like that when i plug charger power switch light direct on and cant off even push and hold for long time
Even no display
I can on/off through on battery only, on battery also no display
almost i replace all IC but same problem facing
any one have idea
Dell N5010 Power On/Off Problem
Re: Dell N5010 Power On/Off Problem
you can explain proper . wich ic replace or resold
Sir I did replace
Replace BQ24745 Battery Charging IC
Replace RT8205
Replace BIOS IC and Reprogramme also
Replace IO ic also
after that problem are same
When plug charger power on/off switch light glow on, and cant off,
only while battery plug laptop power on and off but no display
i hope u understand now bro
Replace RT8205
Replace IO ic also
you can reball or replace ATI chip
Bro its a W/o Graphics MB
Put snaps off your motherboard ...
DO u Have PSU .....If yes then whats the reading of amps ....?
try to change io board ...
