HP 15 / R62 BOARD POWER ON NO DISPLAY / 5V IC HEAT
skbasir
Post by skbasir »
HP 15
BOARD PART --- R62 BOARD
PROBLEM-----
POWER ON ...NO DISPLAY .200AMP LOAD ONLY
STEPS BEFORE DIAGNOSIS FIRST LOOK
FIRST LOOK IN DC JACK FOR POWER LED.... BUT POWER LED NOT GLOWING AFTER CONECTING ADP ,,,, BUT SYSTEM JUST POWER ON WHEN PRESS POWER SWITCH ....AND TAKEING .180 amp IN DC SUPPLY... WHICH IS WRONG ..... BEFORE POWER SWITCH ON BOARD LOAD SHOULD BE .03amp FOR NORMAL OPRATTION..... AND WHEN BOARD ON MARK FAN NOT WORKING ..... THIS IS FIRST SUSPECT FOR 5V AREA ISSUE..........
DIAGNOSIS STEP FOR CHECK ISSUE
CHECKED AT FIRST BOARD WHERE 5V IC GETTING HEAT EXCESS
THEN CHECKED FOR THAT 5V COIL FOUND 2.2V INSTED OF 5V
SUSPECTED 5V IC SHROT OR ANY 5V RELATED COMPONET SHORT
THEN CHECKED FOR IMEDANCE OF 5V COIL IS NORMAL... MEAN SOME ISSUE IN VREG VOLT OF 5V IC
THEN I GO FOR CHECK VCC5V IN PU10 PIN11 FOR 5V ,,, BUT HERE GETING ONLY 0 V
HERE SHOULD BE 5V FOR NORMAL OPERATING
THEN I CHECK THIS PIN IMPEDANCE AND FOUND LOW AND SHORTED WITH GND
THIS PIN IS ONLY CONECTED WITH ONE CAPACITOR PC228 AND CHECKED ... FOUND THIS CAP IS SHORT
THEN REMOVE THIS CAP SHORT CLEAR AND PIN 11 IS NOW 5V AVAILABLE AND 5V REGULATOR IC ALSO NO HEATED
BUT STILL ONLY 2.2V AVIL IN 5V COIL WHEN PRESS POWER SWITCH
THEN I SEARCH FOR THIS CAPCAITOR VALUE 1U/6.3V IN BOARD FOR REPLACE IT
THEN I SEARCH IN SCHEMATIC FOR "1U/6.3V"
MANY PLACE I FOUND IT AND ATLAST C509 CAPCITOR FOUND FOR SAME VALUE
THIS IS C509 CAP PLACE IS BEHIND THE PCH AND ALSO MARK IN PICTURE
THEN REMOVE THIS C509 AND PUT IT ON PLACE OF PC228
NOW POWER ON THE BOARD AND 5V ALSO FOUND IN 5V COIL AND FAN ALSO WORK AND BOARD ALSO WORKING FINE NOW
RESOLUTION
JUST REMOVE THE PC228
REMOVE THE C509 AND PUT IT IN PLACE OF PC228
JOB DONE SUCCESSFULLY
THIS IS THE DEFAULT ISSUE IN PARTICULAR R62 MODEL JUST PC228 SHORT FOUND MANY TIMES
MANY TIME FOUND 5V IC HEATING 2.2V INSTEAD OF 5V
AND ALSO THIS ISSUE IS ARRIVE IN PARTICULAR THAT TYPE OF BOAR WHICH BOARD HAVE SEPARATE IC FOR 3.3V / 5V
HOW TO FIND 1U/6.3V CAP IN SAME BOARD BY SEARCH IN SCHEMATICS
PC228 IN SCHEMA WHICH IS CONECT IN PU10 OF PIN 11 ONLY ONE CAPACITOR
C509 PLACE 1U/6.3V (BACK SIDE OF PCH)
PC228 SHORT AND ITS PLACE
5V IC HEAT AND IN COIL 2.2V ONLY INSTEAD OF 5V
BOARD MODEL R62
BOARD MODEL R62
Re: HP 15 / R62 BOARD POWER ON NO DISPLAY / 5V IC HEAT
very very nice post thanks for give info,
ganeshcell
Post by ganeshcell »
thanks for this great info
thanks for thish info. i also face it problem . thanks bro.
nice sir
skbasir
Post by skbasir »
THANKS TO ALL
Juandi
Post by Juandi »
Good job sir
samanthban
Post by samanthban »
Nice sharing
Himal
Post by Himal »
Nice Sir
raajkumar
Post by raajkumar »
All information is valuable. You done a great job. thanks
