HP15 Display Flicking and sometime not Power on
Description: HP Pavilion 15 Display Flicking and sometime not Power on Found Problem 19V +VE Line Problem and Display Section Problem
Manufacture: Hewlett-Packard
Model: 15-n010tx
Motherboard Part No: DA0U81MB6C0 REV: C
Processor Type: SR0N9
Ram Type: DDR3L
Problem: Display Flicking and sometime not Power on
Diagnosis: Found G5243AT11U (+3VLCD_CON) Faulty and G5934RZ1U Input line Resistance Open
Process: HP 15-n010tx Laptop Received some time on and sometime not and when on display problem some time white display and sometime flicking. When open laptop found motherboard DA0U81MB6C0 REV: C part number open checking motherboard not found physically any damaged or rusted part. Then connect power found not glowing power Led and checking voltage 19+VE power input and Found Not coming Power PU6 (G5934RZ1U) Pin15 Voltage And found R144 damaged physically. after replace R144 19+VE coming PU6 Pin15 and Power LED glowing . Laptop On And Display Coming With Flickering and White Again checking display section Voltage and Found Display section IC U1(G5243AT11U) Output Voltage Is Some time Drop (+3VLCD_CON) After Replace U1 Voltage Not Drop And Display Flicking Off and Laptop Running Working
Motherboard
Motherboard
Power LED
Power LED
Power LED.JPG (25.2 KiB) Viewed 1888 times
PU6 Power Open
PU6 Power Open
Display Problem
Facebook
ganeshcell
Re: HP15 Display Flicking and sometime not Power on
Post by ganeshcell »
Great Sirji
Users browsing this forum: Bing [Bot]2 and 58 guests
