Hi All,
I have got Acer E5-511 where i need to flash the bios chip 25lq64csig . but in the tl866 software i cannot find the chip details. is there any way to flash this chip. or any compatible bios chip for this model. I have seen this is a low voltage chip and to flash this type of chip on normal programmer you need a special type of adapter which is listed on ebay. Any help from experts in this matter is required,.
Thanks.
programming 25lq64csig with tl866 programmer
Re: programming 25lq64csig with tl866 programmer
select the IC and see its adaptor info. There is schematic for modification for this IC
thanks i will check and update
