Some Panel Signal & their Working
All Data Get From Open Social Media Group .
we are not make any change in data use at your own risk
suryajaved
(1)STV
Vertical Sync Input.
The rising edge of STV begins a frame
of data. The STV input is used to generate the high-voltage STVP output.
(2)STVP
High-Voltage Scan-Drive Output.
STVP is connected to VOFF when STV is low and is connected to VON when STV is high and CPV1 is low. When both STV and CPV1 are high, STVP is high impedance.
(3)CPV1
[hidden]CPV (Clock Pulse Vertical) -Vertical Clock Pulse Input.
CPV1 controls the timing of the CKV1 and CKVB1 outputs, which change state (by first sharing charge) on its falling edge.
(4)CPV2
CPV2 controls the timing of the
CKV2 and CKVB2 outputs, which change state (by first sharing charge) on its falling edge.
(5)CPV3
CPV3 controls the timing of the
CKV3 and CKVB3 outputs, which change state (by first sharing charge) on its falling edge.
(6)CKV1
CKV( Clock Signal)- High-Voltage Scan-Drive Output.
When enabled, CKV1 toggles between its high state (connected to VON) and its low state (connected to VOFF) on each falling edge of the CPV1 input. Further, CKV1 is high impedance whenever CPV1 and STV are both low.
(7)CKV2
When enabled, CKV2 toggles between its high state (connected to VON) and its low state (connected to VOFF) on each falling edge of the CPV2 input. Further, CKV2 is high impedance whenever CPV2 and STV are both low.
(8)CKV3
When enabled, CKV3
toggles between its high state (connected to VON) and its low state (connected to VOFF) on each falling edge of the CPV3 input. Further, CKV3 is high impedance whenever CPV3 and STV are both low.
(9)CKVB1
CKVB (Inverted Clock Signal)- High-Voltage Scan-Drive Output.
CKVB1 is the inverse of CKV1 during active states and is high impedance whenever CKV1 is high impedance.
(10)CKVB2
CKVB2 is the inverse of CKV2 during active states and is high impedance whenever CKV2 is high impedance.
(11) CKVB3
CKVB3 is the inverse of
CKV3 during active states and is high impedance whenever CKV3 is high impedance.
(12)CKVCS1
CKV1 Charge Sharing Connection. CKVCS1 connects to
CKVBCS1 whenever CPV1 and STV are both low (to make CKV1 and CKVB1 high impedance) to allow CKVB1 to connect to CKV1, sharing charge between the capacitive loads on these two outputs.
(13)CKVCS2
CKV2 Charge-Sharing Connection. CKVCS2 connects to
CKVBCS2 whenever CPV2 and STV are both low (to make CKV2 and CKVB2 high impedance) to allow CKVB2 to connect to CKV2, sharing charge between the capacitive
(14)CKVCS3
CKV3 Charge-Sharing Connection. CKVCS3 connects to
CKVBCS3 whenever CPV3 and STV are both low (to make CKV3 and CKVB3 high impedance) to allow CKVB3 to connect to CKV3, sharing charge between the capacitive loads on these two outputs.
(15)CKVBCS1
CKVB1 Charge-Sharing Connection. CKVBCS1 connects to
CKVCS1 whenever CPV1 and STV are both low (to make CKV1 and CKVB1 high impedance) to allow CKV1 to
connect to CKVB1, sharing charge between the capacitive loads on these two outputs.
(16)CKVBCS2
CKVB2 Charge-Sharing Connection. CKVBCS2 connects to
CKVCS2 whenever CPV2 and STV are both low (to make CKV2 and CKVB2 high impedance) to allow CKV2 to connect to CKVB2, sharing charge between the capacitive loads on these two outputs.
(17)CKVBCS3
CKVB3 Charge-Sharing Connection. CKVBCS3 connects to
CKVCS3 whenever CPV3 and STV are both low (to make CKV3 and CKVB3 high impedance) to allow CKV3 to connect to CKVB3, sharing charge between the capacitive loads on these two outputs.
(18)BOOST
Operational Amplifier Supply Input. Connect to VMAIN
and bypass to BGND with a 1μF or greater ceramic capacitor
[/hidden]
Return to “Tips & Trick”
Users browsing this forum: No registered users and 99 guests
