How To Create Windows 10 Hotspot
Everyone enable windows 10 Wi-Fi hotspot without any software you can use only two command
1st command is “netsh wlan set hostednetwork mode=allow ssid=mywifiname key=mypassword “
1st command type.png (11.21 KiB) Viewed 2100 times
2nd command is “netsh wlan start hostednetwork “
Using method
Open command prompt and type this command 1st for create HOTSPOT
Cammand massage netsh wlan set hostednetwork mode=allow ssid=mywifiname key=mypassword.png
“netsh wlan set hostednetwork mode=allow ssid=mywifiname key=mypassword”
You can use ssid= any name you can use and “key= Any Password”
Then use 2nd command for start hotspot
"netsh wlan start hostednetwork"
after using this command open control panel
go to network and internet
then go to network and sharing then change adapter setting
then go to fi-fi or Ethernet property
then go to sharing tab then check box
(allow other network users to connect through this computers internet connections) click check then select local area connection 3
Hotspot Setup.rar
(518 Bytes) Downloaded 925 times
prakash pal
Re: How To Create Windows 10 Hotspot
Post by prakash pal »
VERY NICE
Return to “How to... ?”
