hp 15-be002tx not power on
satish panchal
Post by satish panchal »
board part no... bdl50 la-d704p
rev :1.0
not power on
when i plugged an adapter then heating 8a-3d regulator chip..
i find but no any shorting
i replace these chip ..but same problem...
siriki85
Re: hp 15-be002tx not power on
Post by siriki85 »
slt il faut bien tester le mosfet de puissance car souvent en test simple il se comporte bien donc verifie le bien a defaut change le merci
Return to “ASK FOR HELP”
