HP 15-AC-150TX LA-C701P POWER ON 3 BEEP
computerclinic
Post by computerclinic »
Sir,
HP Laptop 15-AC-150TX LA-C701P POWER ON 3 BEEP
New Bios File Falshed but Same Problem,,
Help Me........
Thank You...............
computechsalem
Re: HP 15-AC-150TX LA-C701P POWER ON 3 BEEP
Post by computechsalem »
Check the corrosion on ram slot lines, for conversion remove gfx coils only, post the reply board response after removing gfx coil. also find board id resistor
bluestone
Post by bluestone »
3 beeps mean Ram error, check the ram well, and also check if you have 1.3v at the ram coil
Users browsing this forum: No registered users and 27 guests
