I have Dell 15 3542(13269-1)no power.
19v ok
3.3v ok
5v ok
No shorts in motherboard.changed io,flashed bios.changed charging ic,regulator ic,vram,ram ic but no result.power switch voltage is ok.
when i press power switch,power led blinks once.plz help
Dell 15 3542(cedar intel mb 13269-1)no power
Re: Dell 15 3542(cedar intel mb 13269-1)no power
Sorting in mb
Sorry but there is no shorting in mb.which section to check any idea?
Current rating in psu ?
Small pf short check in cpu heatshink base remove the base check it or some track cut in motherboard use magnifying glass.
reflow cpu or main chip
