Hi
I have Dell Inspiron N4050 without ram given 2 beeps but when i insert ram, machine restart randomly with no display.
ram voltage 1.5 is ok
i changed super i/o but there is fault still.
can any one help me...........
Dell Inpiron N4050
Re: Dell Inpiron N4050
Hi,
First check with another ram in slots (for better result test mobo without hdd,odd and wireless card),then if still have problem, program bios ic and ec if it has (don't forget to take backup from current bios)
goodluck
goodluck
plz follow the power sequence..
Check for Short circuit Capacitors on the Motherboard over the PCH area and the back side also.
i got the same problem which was solved by flashing bios
