sony MBX-224 battery not detected.
utpalsil@gmail.com
Post by utpalsil@gmail.com »
sony mbx-224 battery not detected and set is get off with battery.
first i chenge battery. but same.
chenge charging ic. but same.
chenge i/o controller. but same battery not detected.
then i checked throughly, and after that i found ic pu5 is defected.
chenge the ic and problem solved.
thank you. :D
Re: sony MBX-224 battery not detected.
thanks for shairing
