Acer NE46RS1 15 Sec off
kirubakaran
Post by kirubakaran »
compliant Laptop dead,
charging ic brun the i will change,
after io overheat also change ,
Now laptop on but no display and 15 sec off
bios also Flashed
all voltage are ok...
Re: Acer NE46RS1 15 Sec off
do not come to the conclusion that Bios program is corrupt, plz check all supplies first if all supply means ram termination, sus, run supply also to be good and up to mark after that clock should start. than LPC communication
