CASE STUDY ACER 4739Z POWER ON AND OFF IMIDIATLY
MODEL --- ZQH
OBSERVE
LAPTOP POWER ON AND OFF IMMITIATLY AFTER 5sec
DC AMPERE LOAD WHEN POWER ON .400
THEN OFF
CHECKED FIRST ALW VOLTAGE FOUND OK 3/5 ALW
CHECKED +15V ALW OK
CHECKED S0_S5 VOLTAGE ALL OK
CHECKED THE S5_ON SIGNAL OK
CHECEKD S0 VOLTAGE AFTER POWER ON FOUND LOW
+3V = +2.1V
+5V = +3.4V
CHECKED ALL MOSFET OF S0 GATE FOUND 4 TO 5V MEANS MAIND SIGNAL LOW .. IT SHOULD BE MINIMUM 10V
THIS IS COMING FROM PQ25
THIS FAULT IS ONLY MAINON AND MAIND SIGNAL ISSUE
CHECKED AND FOUND MAINON SIGNAL IS COMING 3.3V AFTER POWER ON IN PQ26 ..BUT AGAIN BECOME ZERO
MEANS MAINON CANT CONSTANT ....IT SHOULD BE CONSTANT AFTER POWER ON FOR OK CONDITION
CHECKED AND FOUND PQ26 IS OPEN .. SO THAT MAINON DROP AFTER ON OF 5sec
REPLACE THE PQ26 AND CHECKED MAIN ON OK AFTER POWER ON 3.3V CONSTANT
THEN CHECKED MAIND SIGNAL BECOME 12V IN PQ25
AFTER REPALCE OF PQ25 ALL S0 VOLTAGE FOUND OK MEANS +3V/+5V OK
BUT STILL IN DC SUPPLY ONLY .400amp
Again checked AND FOUND +1.8V MISSING RUN VOLTAGE AT PQ60 PIN 1...2..3
CHECKED MOSFET GATE PIN4 HAVE NO VOLTAGE
THIS DRV VOLTAGE COME FROM PU12 IC PIN 5
CHECKED THIS IC FOR VCC AND EN FOUND OK BUT NO OUT PUT IN PIN 5
REPLACE THIS IC AND CHECKED PIN 5 HAVE DRV VOLTAGE
NOW RUN VOLTAGE +1.8V GENERATE IN PQ60
NOW BOARD TAKE MORE THEN 1AMP IN DC AND BOARD ALSO CONSTANT ON
DISPLAY COMING
AFTER LONG SEARCH AND LONG RESAECH
RESOULATION
ONLY CHANGE PQ26 & PU12 IC
JOB DONE SUCESSFULLY
- Acer 4739Z ON AND OFF 5se.rar
- (9.41 MiB) Downloaded 497 times
Re: CASE STUDY ACER 4739Z POWER ON AND OFF IMIDIATLY
nice sir ji
- samanthban
Thanks for sharing
good job sir
can you send picture sir
VERY NICE THIS TOPIC VERY HELPFULL SAME PROBLEM IN ACER ZE6 LAPTOP ALSO
Users browsing this forum: Bing [Bot]2 and 38 guests
