dell latiude e5420
satish panchal
dell latiude e5420
Post by satish panchal »
uma : 10ELT16G001-A
NO DISPLAY AND POWER CUT IN 10 SECONDS....
anirash25
Re: dell latiude e5420
Post by anirash25 »
Received a same Issue ..Problem Resolved after flashing the Bios..
Else the most Common issue in the E Series would is Corrosion ..Check tat
satish panchal
can u send me bios file of this board
anirash25
Post by anirash25 »
Pls share the MB Part No
satish panchal
14" uma:10ELT16G001-A
satish panchal
I HAVE ATTACHED MOTHERBOARD IMAGES ...JUST SEE AND THEN GIVE ME ORIGINAL BIOS FILE
Nadeem-Amin
Post by Nadeem-Amin »
Please chk this
Dell 5420 KRUG 14 UMA 10ELT16G001-A.rar
(2.39 MiB) Downloaded 474 times
satish panchal
same problem ......
check cpu core ic if voltage is available. then dry the ic sir
satish panchal
can u tell me cpu core ic number ?
