+1.05VTT_PWR CPU AND PCH POWER RAIL SHORT TO GROUND
DELL N5040 DV 15 CP UMA MB 10263-1
This laptop came as no power ,first check 19v rail was short to ground and removed easily .cap was pc 4813
then checked PL4902 short to ground as shown in the picture .
I failed many time when injecting voltage to this rail . and i have checked PC4901,PC4910,PT4902,PT4901 all are ok.
please give an advice any expertise regarding this matter.
Re: +1.05VTT_PWR CPU AND PCH POWER RAIL SHORT TO GROUND
Schematic is attached
dell-n5040-.rar
(1.31 MiB) Downloaded 524 times
At first check the mosfets amd then 1.5vtt line where it goes
Then post the results
esmat-fadak wrote:At first check the mosfets amd then 1.5vtt line where it goes
Thanks for replying, all fet are checked and ok. this rail is end with 100-150 component .without checking all component isolate narrow area will be easy .
This is solved ..this is completely normal This rail is short to ground :lol: one of a forum member informed. then only realized .what a wast of energy and electricity :twisted: learnt many things from this board ..laptop working 100% :)
