No display
sibu
No display
Post by sibu »
HP Pavilion 15 No display issue
Motherboard Model: DA0U82MB6D0 REV:D
I want to know How to fix the issue
I can also try flash the bios, replace the core ic, replace the vrm section mosfet
and check all voltage and all voltage is properly available in the all sections coil
and i found the fault that processor is not getting heat
Please help how to fix this issue.
Re: No display
Do you followed the board sequence or just hit and try . we request you to follow the supply sequence and then plz ask for the help...
Re: No display
core supply is ok sir or not ,,if ok u check clock of cpu and pch plt/pci rest sinal ,,,and also check io for vron signal for core suplly on.
