Delll vostro 1015 plugged in not charging
shlnarang
Post by shlnarang »
Laptop - Dell vostro 1015
Problem- plugged in not charging
Charging ic- max8731a
In bios it shows adapter type=65w and batery health = normal but 0%
Dcin- 19 volts
Acin- 3 volts above
Ac ok-3volts above
Scl,sda-3.3 volts
Psid-Ok
Dhi - 0.7 volt
Dlo -0volt
What could be the problem battery or in motherboard ???
Help please
manikodai
Re: Delll vostro 1015 plugged in not charging
Post by manikodai »
To be check chrgng volt in connector. Depending on battery. Its ok check battery or xhange new battery
ali4799
Post by ali4799 »
check battery or charjer
shlnarang
Post by shlnarang »
Charging volt 0 on battery connector
shlnarang
Post by shlnarang »
rajeshkumar45
Post by rajeshkumar45 »
it should bee your battery problem sir
