Lenovo g430 keyboard problem
shlnarang
Post by shlnarang »
I have a g430 laptop internal keyboard is not working normally all key responds very slowly after a minute i have changed the keyboard reflashed bios,changed cpu ,changed io controller,ram,hdd too and external keyboard works normally what could be the problem ??
Re: Lenovo g430 keyboard problem
In this case First of all check the keyboard connector and EC connections impedance must same. Aur remove if capacitors on these lines.
shlnarang
Post by shlnarang »
No capacitors are there ,there are some rn resistors i tried replacing them too !!
milind
Post by milind »
good job thanks for sharing
