compaq 420 pulug in not charging
3v/3v/3v/ come on battery conn,
Re: compaq 420 pulug in not charging
Without power plugged in
tell me the voltage at battery connector all pins ...(with battery)
[ Post made via Linux Laptop ] Image
sir battery positive supply and two 3v/3v. comes at battery connector ..
Am0rPHiA
Post by Am0rPHiA »
does the laptop turn on without battery? if ac goes in but battery does not charge then either the battery is faulty or charging ic is faulty usually a maxim , do you have board schematic or part number of the board?
Battery positive voltage is it above 9v or below 9v?
battery positive pin have 7,2 v
Your battery is in deep discharge condition ...kindly change ur battery and check .....minimum charge position must be around 9v
sunil
ok sir thanks
