PCH FAULTY OR NOT?
ravichouhan
PCH FAULTY OR NOT?
Post by ravichouhan »
2. HOW TO CONFIRM PCH FAULTY OR DRY?
gurmeet singh
Re: PCH FAULTY OR NOT?
Post by gurmeet singh »
Check rtc section working conditions. If rtc working good then check ec working conditions . If ec working conditions meats to requirement then check bios if s5 is not released .
To varify PCH is Faulty
On cold test Check Pin8 on Main bios if the resistance is low or 0 and there is no other shorting in 3.3V line components then u can be pretty sure that u have problem with ur PCH
Check the SUSB and SUSC resistance with respect to ground ...if low then it may be one of the reason for PCH gone bad
other physical conditional also matter and sometimes like in 5050 board u find GFX coil shorted without cpu load ...in these conditions
we can make sure pch is faulty...the capcitor on PCH itselfs shows short ...
Thanks
sunil
[ Post made via Linux Laptop ] Image
Users browsing this forum: No registered users and 3 guests
