HOW TO USE DC SUPPLY IN PROPER WAY
SOME MY FRIEND CIRCLE LAPTOP REPAIRING...THEY USE DC MACHINE QJE AND OTHER MAKE .. THEY SEE LOAD ON AMP METER AND RIGHT GUESS WHICH SECTION IS INFECTED .... SO I ASKED MY SENIORS WHAT THE RIGHT WAY USES OF DC MACHINE .....
- mehtabbukhari
Re: HOW TO USE DC SUPPLY IN PROPER WAY
Dear Ermansha,
As such there is no specific methodical approach to this. But, you can either use an isolation method or can sense an overheating component by supplying appropriate voltages with the limited current to specific power sections.
If your regulated power supply does not have a preset to regulate current inductance then you will have to be very careful with this method.
good sharing
