Replacing NEC token
kevinmathew
Replacing NEC token
Post by kevinmathew »
Component:- NEC Token
Placed behind processor
Symptoms:- Not booting, no power ON, etc...
Model :- Samsung, Toshiba, MSI, etc...
Solution:- Remove NEC and put 6 no. of 330 Capacitors or 4 no. of 470 Capacitors.
I think many people don't know this, if you are one of them please comment for more
:ugeek: :ugeek: :ugeek:
Re: Replacing NEC token
nice
Am0rPHiA
Post by Am0rPHiA »
sometimes this also works for models that have 4 capacitors around the cpu socket like toshiba L300D, not only for NEC tokin
these caps also need replacement
nice post
pridecomputers
Post by pridecomputers »
FOR L300 NEED 3 NMBR CAPACITORS
raajkumar
Post by raajkumar »
I had same issue. but in my experience i have done more than 15 laptops by replacing 4 330Uf 2.5v Tantalum. All laptops working fine. Now i have a problem in L300. after i replaced 4 caps it worked for one week only. thereafter its screen goes white blank. i try to flash the bios and replaced LCD reflow the Intel Northbridge chipset. the problem still have.
thanks for shairing
Users browsing this forum: sauravh sahu and 11 guests
