ACER 5740 does not turn on
Hey guys,
ACER 5740 (motherboard JV50-CP MB 09285-1M) does not turn on and no display.
When power button is pressed, power leds turn on, exactly after 1 second, they turn off.
I checked all voltages and they seem fine, when power button is pressed. PLTRST is also fine.
Exactly after one second from turn on, it looks that SLP_S3# and SLP_S4# are turned off by PCH causing system off. All powergood signal is OK.
I have downloaded BIOS from ACER website and flashed, but the set still does not turn on. I have also reflowed the PCH HM55, but no luck.
At this point, I guess that I have bad PCH/ CPU.
Can anyone help me to troubleshoot, i would appreciate that before i go for PCH/ CPU change. :D
Re: ACER 5740 does not turn on
Anyone? Any guess? I am going ahead with HM55 replacement. Hope this solves the issue. Wish me luck..
deepak9812423104
Post by deepak9812423104 »
3v n 5v coming or not,,,,in controler powerbutton on and downbutton droup or not.....
I told PLTRST is OK, of course all voltages are OK, and signal to pch on power button press is OK. But it powes off exactly after 1 second.
Another interesting observation is that the RSMRST to PCH is missing. Upon further investigation, I find the pull up resistor to RSMRST and diode in series were missing. I added those, but still SIO is not sending RSMRST to PCH upon power button press.
Can anybody confirm that RSMRST goes high upon power button press on this board?
Users browsing this forum: No registered users and 83 guests
