many hp motherboard lost +vcc_gfx yesturday got a r13 mb no +vcc_gfx please any one tell how it solve
i done bios, i/o change
ic change core volt also change even reball and replace pch also bt no solution
+vcc_gfx voltage missing
Re: +vcc_gfx voltage missing
you have to change vrm ic and if still the voltage is not coming so please replace the processor you defiantly have results.
all done tested cpu repace and test that cpu on other board its working
Hi, I have one R13 motherboard, +VCC_GFX is 0.45V, the LCD panel just light up but no video (VGA neither). Anybody can tell me if this voltage is correct? Thanks.
+vcc_gfx voltage correct its 0.45V
