SIMPLY WAY TO HELP LOCATE FAILURE AREA ON NO DISPLAY PROBLEM
When you try to solve no display problem on laptop motherboard.after measure all voltage rail is ok,re-flashing bios but no result.cek visual of motherboard is ok.and curent consumption slightly below normal motherboard when display .you can try this trick
Rehoot/ heat from the bottom of the chip with hot air arround 3 minute or more which is suspected dry joint / lead crack / or chip failure.. wait for a moment until themperatur slightly decreased..and test the motherboard.if curent consumption of motherboard increase ... you can go to next step..reball this chip
Re: SIMPLY WAY TO HELP LOCATE FAILURE AREA ON NO DISPLAY PROBLEM
Thank's Mr. Billy
thnx sur ji
good informations
Nice trick
Thx for sharing
Thx for sharing
