COMPAQ CQ42 QUANTA AX1 DEAD
mcplslg123
Post by mcplslg123 »
M/B: QUANTA AX1
MODEL: COMPAQ CQ42
PROBLEM: DEAD
This mb came dead. No light on dc jack.
3v, 5v rails present
no short to ground anywhere.
sensing voltage at battery connector & power switch present
after much effort found that SIO kb3926QF D2 was faulty as pin no 90(DNBSWON#1) should have 3.3 volt but was giving only 1.45 volt. This signal originates from kbc.
Replaced kbc. Now ok
samanthban
Re: COMPAQ CQ42 QUANTA AX1 DEAD
Post by samanthban »
This signal (DNBSWON#1)comes after pressing the power button.your lap is dead .please correct me if I'm wrong
mcplslg123
Dear Samanthban, This is what i do mean also. After pressing power switch DNBSWON SHOULD BE 3.3V BUT WAS GIVING 1.45V.Yeh laptop was dead.
samanthban
Thanks for replying some what you did is correct learnt one thing thanks .I used to go for S4/S5 command .
Users browsing this forum: Bing [Bot]2 and 31 guests
