Dell N5010 blank screen after graphic convertation
Plz help.In Dell n5010 i m geting only light and no data in screen after graphic convertation.Plz give any solution.Thanks in advance
Re: Dell N5010 blank screen after graphic convertation
Solved.One coil was mising
Plz. tell which coil is missing, even i am facing same problem
What problem you facing white screen or black screenAnees123 wrote:Plz. tell which coil is missing, even i am facing same problem
Plz see the image in rar file.place the coil carefully given in the red circle.Lots of people make this mistake while converting.i also made this mistake but now i have done this conversion on more than 70 boards.
- 20161212_141636-1.rar
- (641.98 KiB) Downloaded 371 times
Thanks ganeshcell
