how to use dc supply to find short component on motherboard
Swanand
Post by Swanand »
in this case study
i am using dc supply to remove 19v line short circuit
in short circuit case dc power supply becomes handy to find the exact short component
to do the job set dc power supply to lower voltages like 0.5 or 1v...not more then that in dead short conditions
then inject voltages of dc supply to the short line
do not connect power adapter in this trick
after injecting voltages with dc power supply check motherboards components carefully for heating of a component
component which is short will start heating...
find the heating component
remove those components which are heating after & check ...shorting will be gone
attached is a sample case study with vin line or 19v short which was repaired with dc supply help
case study
Regards
Swanand
md solution
Re: how to use dc supply to find short component on motherboard
Post by md solution »
Good idea
good job and good tutorial
prakash pal
Post by prakash pal »
G8 trick sir ji..... Plzzzz upload 3/5 V shot means how to use dc power supply n how to find out
santosh_rawat
Post by santosh_rawat »
Directly inject 3.3v at 3.3v coil without attaching afapter.if any Component is heating.that means those component is faulty..this method for 3.3v shorting finding.
billysukmasyarifudin
Post by billysukmasyarifudin »
thansk alot sir...very useful information
rahulsan
Post by rahulsan »
THANKS SIR VERY USEFUL TUTORIAL
