Description: Dell Insprion N5010 No Display Continues 3 beep sound Replace ATI Chip Problem Solved
Make/Model: Dell Insprion N5010
Motherboard Part No: DG15 MB 48.4HH01.011
Processor Type: I5 First generation
Ram Type: DDR3
Keyboard Controller: NPCE781BA0DX
Problem: No Display 3 beep sound
Diagnosis: Processor Power Supply and ATI Faulty
Process:
Dell Insprion N5010 Laptop No Display And Continues 3 beep sound open laptop and found Motherboard DG15 MB 48.4HH01.011 , after clean motherboard found near PU4701 ( ISL62883HRTZ) Rusted after clear rusted ic coming Display But Water Very Bad luck this display coming without ram and Processor , Then Check Found VGA1 (ATI 216-0729042) Overheating after replace VGA1 IC display coming proper , then Laptop Work Proper
Dell Insprion N5010 No Display Continues 3 beep sound Case Studies Rev 1.1
Re: Dell Insprion N5010 No Display Continues 3 beep sound Case Studies Rev 1.1
Well according to dell diagnostic its come many resion BT display come without CPU nd ram if only if screen got 2 signals one by lvds on its 3.3 nd other backlight on its also 3.3 BT this bkon run by i/o blank display all work prop BT it needs CPU nd ram to follow post that only init the bkon on
Sorry this Sol can't assume be on way
not coming data only back light onavdesh1 wrote:Well according to dell diagnostic its come many resion BT display come without CPU nd ram if only if screen got 2 signals one by lvds on its 3.3 nd other backlight on its also 3.3 BT this bkon run by i/o blank display all work prop BT it needs CPU nd ram to follow post that only init the bkon on
thanks for reading carefully this post !!!!!!!!!!!!!!!!
bro its some time i create on n5010 2 times for a case bt by default i do just put jumpres over 3.3 regulator in order to make unrepair system give
Dell N5010 Getting 3 Beeps , Sometime Display ok, What to do .....
Users browsing this forum: No registered users and 28 guests
