DELL 5010 SHUTDOWN AFTER 1min AUTOMATICALLY
skbasir
Post by skbasir »
LAPTOP SHUTDOWN IN 1 MIN AUTOMATICALY (RESOLVE AFTER LONG TIME)
MODEL- DELL INSPIRION 5010
BOARD PART - DG15 MB 099091-1
DIAGNOSIS@@@@
CHECKED FIRST THIS IS GRAPHICS MODEL AND IT MADE EXCESS HEAT
CHECKED FAN NOT ROTATE
CHECKED FAN CONECTOR THERE IS NO 5V IN PIN 1
THEN GIVE 5V TO FAN PIN 1 FROM USB LINE
AFTER THAT FAN WORKING BUT STILL SAME ISSUE SHUTDOWN IN 1 MIN
THEN THOUGHT THIS IS ATI ISSUE
SO GO FOR INTEL CONVERT AND CONVERT TO INTEL AND CHECKED SAME ISSUE
THEN I DO BRUSH THE BIOS BUT SAME ISSUE
THEN AGAIN BRUSH BIOS WITH CLEAN ME REGION BIOS ALSO SAME ISSUE
THEN REPLACE ALL THERMAL SENSOR Q3901,Q3902,Q3904,Q3905 BUT SAME ISSUE
THEN I REPLACE CPU AND REFLOW PCH ALSO SAME ISSUE
CHANGE THE HEAT SHINK WITH FAN SAME ISSUE
THEN TOUGHT IF TO RESOLVE THE FAN VOLTGE MAY BE WORK
THEN GO TO CHECK FAN PIN 1 NO 5 VOLTAGE
TRACE IN SCHEMATICS FAN PIN 1 CONECT TO THERMAL IC U3901 PIN 25,26 THERE IS NO VOLTAGE
CHECK THE PIN IMEDANCE OK BUT NO VOLTAGE
CHECKED THE VDD 5V PRESENT IN PIN 27, 24 OK BUT NO VOLTAGE FOR FAN
THEN REPALCE THE U3901 IC BUT NO VOLTAGE FOR FAN
THEN CHECKED FOR PIN 1 VDD 3.3V RUN ,,,, HERE NO VOLTAGE
TRACE IT FOUND R3902 IS OPEN SO THAT NO 3.3V IN PIN 1
RESOLUTION
JUST REPLACED R3902 RESISTER ALL VOLTAGE OK
PIN 25, 26 NOW 3V TO 5V AS PER HEAT FOR FAN
PIN 1 3.3V
NOW ALSO FAN CONECTOR PIN 1 PRESENT FAN VOLTAGE
AND FAN WORKING FINE
THEN CHECKED BOARD ALSO WORKING FINE NO SHUTDOWN
DONE AFTER LONG TIME 5 DAYS
5010 me clear.zip
INTEL 5010 CLEAR ME BIOS MAIN
(1.84 MiB) Downloaded 364 times
BOARD DG15 MB 09909-1
U3901 AND RESISTER PLACE  R3902 IN BOARD
FAN PIN 1 NO VOLTAGE
U3901 AND RESISTER PLACE  R3902 IN SCHEMATICS
NOW IT WORK FINE
NOW IT WORK FINE
msfaal
Re: DELL 5010 SHUTDOWN AFTER 1min AUTOMATICALLY
Post by msfaal »
thx alot
Zibbo
Post by Zibbo »
Good work
