i have mbx 266 motherboard ..
in this cpu and main chip not heat ..like a 0%
when i power on then 2 minutes in power off automatically
i change bios ,io ,also main chip but no display
no cpu and main chip heat...
mbx 266 no display
Re: mbx 266 no display
check moisture on any compont or ic ..
and check ur 3v and 5v supply working properly
moisture means
moisture means that and dussting components
