WHICH TIME WE ARE USE CRO OR DSO ?
ravichouhan
Cash on hand: Locked
Has thanked: 0
Been thanked: 6 times
Post by ravichouhan » Sun Sep 18, 2016 9:26 pm
1. HI GUYS ANY TELL ME IN WHICH CASE( FAULT) WE ARE USE CRO AND DSO.? AND HOW TO USE?
gurmeet singh
Has thanked: 0
Been thanked: 4 times
Re: WHICH TIME WE ARE USE CRO OR DSO ?
Post by gurmeet singh » Mon Sep 19, 2016 9:38 pm
Dso is must when laptop not turning on even 3v at pwr btn. U must hv to check wave fourm at 32.768 khz cristal .
U will find diffrent wave form at both pins pins of rtc cristal and check sus_clk ,, it is a fullswing square wave of same 32khz will indecate u fine working conditions of rtcrtc . When powered on mobo u must g48mhz at usb port which is the sure short way to check clock is working or not .
ravichouhan
Has thanked: 0
Post by ravichouhan » Mon Sep 19, 2016 10:13 pm
thnks gurmmet sir
minhaj
Has thanked: 0
Been thanked: 2 times
Post by minhaj » Wed May 10, 2017 6:33 pm
thank you sir g
Has thanked: 0
Been thanked: 11 times
Post by javed » Thu May 25, 2017 7:19 pm
usb data pins have 48mhz signal or only one pin sir plz tell
thakkudu
Has thanked: 0
Been thanked: 0
Post by thakkudu » Fri Mar 15, 2019 1:40 pm
thanks you have good knowledge about motherboard, respect you
