Asus P8H61 MLX ON AND OFF
Post by 8000063766 »
Asus P8H61 MLX
PROBLE : ON AND OFF
DIAGNOSIS : ABOVE CPU SOCKET 2 FET AND 3 CAPS SHOW SHORT
REMOVE ALL AND CHECK
ONE ELECTROLYTIC CAP SHORT
SOLUTION : CHANGE IT
MB OK NOW
Tanker
Re: Asus P8H61 MLX ON AND OFF
Post by Tanker »
That was the case for the EN pin voltage Vcore
8000063766
Tanker wrote:That was the case for the EN pin voltage Vcore
NO.....ITS SHORTING IN VRM SECTION
sumesh
Post by sumesh »
some case same symptoms bios issu.....mosfet short case after power one and off going sleep smps...
