dell 1464 problem dim display
dell 1464 problem dim display 1st chekd on my testing screen but same then chekd open and chekd and found 3.3v is missing. thn traced found no output on Q14 FDC655BN thn replace mosfet i got backlite work done..
Re: dell 1464 problem dim display
Good work. Luckily you found the replacement otherwise you need to jumper 3.3V to output pin.
- samanthban
Generally this can be seen in dell laptops
Not only in Dell. I have done in several HP laptop also.
Users browsing this forum: No registered users and 40 guests
