HP 15 / R62 BOARD POWER ON NO DISPLAY / 5V IC HEAT
shamsi
Re: HP 15 / R62 BOARD POWER ON NO DISPLAY / 5V IC HEAT
Post by shamsi »
Yes.this is the common problem for this model.I faced arround 10-15 nos
balu457157
Post by balu457157 »
newlifecomputech
Post by newlifecomputech »
good info, thanks for sharing
Joshuavah
Post by Joshuavah »
So, could I theoretically put my own 12V regulator circuit in the prototyping area left on the shield after the PoE daughter board is installed? Tapping the power from the PoE power inputs directly? Or would this be ill-advised for some reason? Like heat maybe…
