charging issue
charging issue
dell 3521 charging problem ... i can try all ic replace but not success ..plz help
Re: charging issue
hp 15 da0r75mb6c1 mb power on issue ......... when press the power button wifi F12 led blink for 1sec and adapter led off how to fix it
Re: charging issue
adpater led that means shorting in motherboard check....
Re: charging issue
charging issue
Postby sibu » 08-18-2016
ans .. do bios and change battry ...
Re: charging issue
Whats is the exact problem ur facing in Dell 3521 chaging section
1) Display is there or not on motherboard
2) if yes then what error ur getting in windows for battery
3) IN bios if the board is recognising the adaptop status?
what is the voltage on battery connector without battery in power on state?
Get back with therse details for ur query to be solved
regards
sunil
regards
sunil
Re: charging issue
Change the io ic
Users browsing this forum: No registered users and 3 guests
