TOSHIBA C-850-B992
PART NO:PSCBWV
MB : plf/plr/csf/csr uma mb rev 2.1
WHEN I POWER ON SYSTEM ITS GOING WINDOWS STARTING SCREEN AND HANGING....
CHANGE HDD AND TRY TO FORMATTING TIME SAME PROBLEM..
BIOS RE PROGRAMMED...MEMORY CHANGE..HDD CHANGE..
ANOTHER PROBLEM IS WHEN I AM CONNECT BATTERY ALWAYS ON STANDBY LED...HOW TO SOLVE THE PROBLEMS...
TOSHIBA C-850 BOOTING PROBLEM
Re: TOSHIBA C-850 BOOTING PROBLEM
intel chip problem
chnge coreic & mosfit
- Dhirendra Gaur
upload motherboard full image both side
intel chip problem
remove oc resistor , this problem come from pch
It could be CPU, GPU spikes
where"s file bios
