DELL N5010 NO DISPLAY
Posted: Sat Feb 11, 2017 12:45 pm
MODEL:DELL N5010 DG15-09909-1
Switching ok but no display.
It was converted from Ati to Intel by me and worked for last 10 months. Now returned with no display issue.
I have done the following:
01. Flashed main & Ec bios.
02. Changed ram & Cpu.
03. Changed Tps 51125.
3v /5v rails ok. Vcc Core present. Ram voltage present. Vtt 1.05 v present.
I have checked for corrosion and there is none.
Need Help in resolving .
PS: The cpu fan spins a while,then rests a bit and after that spins at 100% speed. Is it PCH bad indicator??
